Targus CityGear Mini for Apple iPad 16GB 32GB 64GB WiFi and WiFi 3G iPad 2 Motorola Xoom Sams Logo
R
Robert Rodgers Posted on Oct 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I forgot my ipad mini password and I would a new one
Forgot password how do 8i get it back or get a new one?
Mikey
Level 3:
Top Expert:
  • Targus Master 6,904 Answers
  • Posted on Oct 05, 2014
 Mikey
Targus Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1623334
Points
26106
Cannot get a new one! Factory reset from PC connection to iTunes!
I forgot my ipad passcode and never synced to a computer
I would just take it to a instore mobile phone repair man/or lady usually chinese are great at what they do not expensive .
1helpful
Forgot password for mini ipad, how do i find my password
Connect ipad to a PC, open itunes and factory reset or restore from there.
Forgot id and password
If you forgot the passcode for your iPhone, iPad, or iPod touch, or your device is disabled Follow these steps if you've forgotten your passcode, or if a message says that your device is disabled.
Forgot passcode for your iPhone iPad or iPod touch or your device is...
I forgot my password and now my mini ipad is disable
it's now in DFU mode and must be plugged up to the computer and connected to iTunes.
I cant hook up too wifi i forgot my netgear password help
Go into the manual, and reset your net gear router. There is a procedure for (almost) every router, to reset it. Then you can reinstall the new security with a new password. You don't need a password, because it is an hardware action of something. Be aware all things that were connected, have to be connected again with the new settings.
Forgot my screenlock code to ipad mini
The only way to unlock your iPad with a lock password, other than entering the passcode, is to restore your iPad to the original factory settings. However, all data on your iPad will be erased if you perform the factory setting restore. Therefore, you'd better back up your iPad data first when you plan to do it.
I forgot my password, and disabled my ipad mini , and need to get back into it
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more methods, check: How to Reset Password on iPhone
1helpful
2answers
Forgot password code for iPad to fire it up
You will need to restore the device if you cannot remember your password. Just connect the iPad to your computer, open iTunes and select the restore option. Be aware this will erase the data on the iPad, but as far as I know you cannot unlock it without the password.
Hopefully you have a recent backup and then can just put the data back once it's been restored.
Hope that helps!
Top Targus Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Targus Tablet and eReader Expert? Answer questions, earn points and help others
