I have a XTH 9 DB35 KW T through hull transducer and a humminbird 858cx model screen on my boat.I have just tried to change the transducer mounting position but the result is the same.The transducer was first placed about 2 mts from the back of the boat and has been moved closer to the center of the boat but the result is the same.I have a 11 mts fiberglass boat with inboard engines.Please help
Be sure you have your unit set in "max mode" and run it on 200khz frequency see if this makes any difference. Also be sure your unit is wired directly to your battery not through a switch or fuse panel as this can rob your unit of voltage, impacting the strength of your sonar signal.
Testimonial: "sounds like a very good idea to tri as mine is connected to a switch panel."
SOURCE: Marine Faria depth finder, with thru the hull transducer.
I'm having the exact same problem. I spoke with the service manager at Faria (Ted) and he was thinking that as long as the gauge is showing a reading, it should default to reading the depth. I'll probably send the guage in to FARIA - they'll repair it for $55. You bring up a good point - maybe the transducer is bad? I put a call in to the Tedmeister to see what he thinks. I'll post if he sheds any light.
SOURCE: does this transducer mount in
Hi!
This transducer requires a hole to be drilled in the bottom of the hull and the unit installed from the outside, using a caulk/adhesive such as 3M 4200 or 5200. Nice choice. Furuno is a good manufacturer!
Hope this helps!
SOURCE: Was working fine when boat was winterized. Now the
Hello Jacovinoa,
I understand that you are having a problem with your Vexilar FL 10 the units is not showing you depths. This can be a problem with the voltage being to below 8 volts when the unit is running. Also you may need to clean the transducer if it has a film of dust on it, it will not read the depths. One other thing you need to check is the angle of the transducer. These are the three possibilities that it can be, if it is not one of these you transducer has went bad.
Thank you for choosing FixYa.com
Justinbur167
SOURCE: Not getting correct readings from
you need to mount it or stop it lifting off the hull tthen move with it sucured
