How do I fix it bymyself
Hi, most likely the power amplifier Integrated circuit or the output transistors got burned. Open the amp, note the specific number indicated on the IC/ transistor values. Get a replacement , remove the bad ones and resoldet the new ones on the board. Hope it will help.
You have probably blown the internal power supply fuses in your amp or the speaker fuse in the amp. The chances of blowing your sub are slim.
The internal fuses can sometimes be hard to find. They aren't usually intended for the user to change. DO NOT replace them with higher amperage fuses if they blow after you replace them as there has been severe damage caused to the circuitry. Also, don't replace them with higher amperage fuses because you think that this will let you get more power out of the amplifier. This won't work, and you will end up blowing your expensive output devices.
