Radio wont work on M630 and M610 radios. Won't search and find strongest stations, wont play known strong stations when manually set. No remote available. Tried different antennas. CD works fine.
SOURCE: sony cdx -m8800
Remove the radio, disconnect the blue wire, and connect the blue/white wire in its place. This should fix your problem.
SOURCE: Sony CDX-M630 will work only with remote.
possibaly the issue is the ribbon cable that connects the faceplate to the head deck i had the same issue
SOURCE: sony cdx-m630
I have a few suggestions that may help. Have you checked the fuses?There is on on the stereo and one in the car's fuse box. Are all of theconnections from the wiring harness secure? Make sure these are tightand show no signs of damage, especially the ground connection. Also, ifthe face is detachable, check the connectors (on the face and thestereo) for damage or dirt or anything that would prevent a goodconnection. Pushing the reset button should not have prevented you fromoperation of the unit, so it has to be either an external fault (likewhat I described above) or an internal problem. How old is the CDplayer? If it is still under warranty, I would call Sony or go to theirwebsite and speak to one of their techs. You can go to the site byclicking on the blue link: Sony Support Hope this helps... Please take time to rate how helpful this was. Thanks and good luck!
SOURCE: Radio stations fuzzy and not coming in anymore - Sony CDX-GT310
i have the same problem, it was a factory fit and the garage checked it and all the connections were ok, it appears to be a fault with the receiver.the radio is just 3 years old.
SOURCE: sony xplod am/fm cd model cdx-m610 will play cds
Make sure that you have the antenna plugged in and if you have a power antenna make sure that you hook up the solid blue antenna wire behind on the radio harness to the power antenna wire from the car plug.
