Go go elite plus 4
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Testimonial: "thanks for the answer so quick il phone them tomorrow"
SOURCE: scooter beep but wont run
Either your parking brake is engaged or if your scooter is more like
mine i have a Rascal 600t it gives a code 5 service code when it thinks
its in free wheel. The freewheel mechanism is located on the trans-axle
which if you go outside across grass it gets wet. Th is device doesn't
like moister and will get stiff will partially engage or disengage. In
that mechanism there is a micro-switch which if the lever when slipped
into the engaged position doesn't go all the way to the seated position
the switch will see the mechanism as being disengaged [in free wheel]
and will inhibit the motor from running. I lubricate the entire
assembly with pure silicon spray oil,WARNING, do not use WD-40, It will
eat some plastics.After lubricating the lever should move smoothly. I
have to lub my scooter about once a month in the winter.
Now if
this doesn't work check the connector that are all the wires are
connected. Disconnect the connector check the pins are ok reconnect
check to see if your still getting the failure. If you are still getting
this problem do continuity checks on the wiring. You will need a
multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Check the switch in the freewheel assembly. Select ohms the highest
scale, short the leads together, zero the meter by turning the zero
adjust knob. There is only one wire we are interested in. On some
scooters you can visually see the switch and the wire running from it.
The wire usually foes to a spade connector. Disconnect the spade
connector put a probe on that connector leading to the switch.
Disconnect the battery put other probe on the positive side of the
terminals that were connected to the battery not to the battery it
side.Work the switch does the meter needle deflect to zero, no, try the
negative side. Does the meter deflect, no, put the probes directly on
the switch terminals, does the switch.when worked now cause the meter
to deflect, no, replace switch, yes, the problem is in the harness,
don't panic, use can use that meter to trace the wire through the
harness. Wiggling wires and flexing connectors usually makes the meter
flick at some point. Thats how i do it i'm never without my trusty
meter. Rascal are notorious for having problems of this type my
mid-frame harness fell apart in the middle of a six lane intersection,
the scooter simply locks up tight .I can do nothing but sit in the
middle of this huge intersection. People try to move me but the scooters
wheels are locked, my illness makes it so i can't communicate with
people do it was a mess. So i modified the connector so its no longer a
latch type connector. I drilled it for a quick pin which is much
stronger than what its using now. Hope this helps
SOURCE: constant beeping but scooter will move
okay there sounds like there either water somewhere or condensation ?
place the whole scooter in a warm room next to a radiator, not too close but close enough so it gets the warmth leave it like this to dry out, this has worked for me, water causing a short either under the tiller panel or where the controller is situated.
regards
