LG 42LG30 42 in. LCD HDTV Logo
A
Anonymous Posted on Oct 04, 2014
Fix black screen
I can hear sound but no picture
1 Related Answer
David Low
  • 458 Answers
  • Posted on Oct 28, 2009
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
2answers
How can I fix black screen on Philips 42" LCD TV?
chances are it is cracked solder joint on internal board,
check link below, press the helpful button
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
42 inch flat screen shows black screen with sound only no picture
That sounds like the backlight system or its powersupply has failed. If you can see an ghost like image when close and at an angle near the dge (depends on the light) then this confirms the backlight being the problem.
Repair cost should be about $100. You should be able to get this fixed under warrenty if you have any. If not get repair estimates before doing anything. It should be worth fixing but it never hurts to know if it is getting close to what a new replacment tv is worth.
Philips Magnavox 36" @10yr old has perfect sound and black screen
checked the vedeo section of the main PCB of the unit, maybe some defective parts, try to look the back of the picture tube if theres a light, if none, cheke also the horizontal section, especially the flyback transformer
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
4helpful
2answers
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Have power but no sound or picture
Goto www.magnavoxhelp.com. They have a kit that will fix this common problem.
TV has audio sound and no picture
major repair; requires 16 pin ic
NO PICTURE/BLACK SCREEN
sound like vertical chip failure or bad connections on the chip
3answers
Black LCD screen and viewfinder in photo take mode
Sony (who bought KM) will fix this for free. http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
