The on/off button has locked up. My battery is charged. How do I unlock the button?
SOURCE: i droped my canon powershot sd 630 now it wont turn on
There really is no way to fix this camera unfortunately. You will need to send it in for service. You can set it up online www.powershot.com or call Canon tech support to set it up for service. There isn't much troubleshooting you can do on the phone with no power. If you are beyond your one year manufacturer's warranty, you may also qualify for the upgrade program for deeply discounted newer models for your camera. At last check, yours qualified for the upgrade to the SD750 for $100 whereas the minimum repair cost for your camera will be probably around $99.
SOURCE: Card locked!
my camera Canon PowerShot SD630 DIGITAL ELPH/DIGITAL IXUS 65 out off work the lenc dsnt work bcose the battry was lowa atar the my camera stop intel now no work please inser me thank you
SOURCE: Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
SOURCE: Canon sd 630 camera won't turn on
Inside the camera, check the brass contacts where the battery connects to the camera. Clean it with rubbing alcohol (use a cotton swab) and try to turn it on after insterting the battery.
