A
Anonymous Posted on Oct 04, 2014
<!-- from fixya rte -->How do you do long division - Office Equipment & Supplies
paulgbrandon
Level 3:
  • Master 661 Answers
  • Posted on Mar 31, 2015
paulgbrandon
Master
Level 3:
Answers
661
Questions
0
Helped
189435
Points
1916
Let's do an example, outlining all the steps.
528 divided by 6
__88
6)528 does 6 go into 5. How many times does 6 go into 52. So put
48 the 8 above the 2. Next multiply 8 times 6 and put the answer
---- under the 52. Subtract 48 from 52. Write the 4 under the 8 in
48 48. Now bring down the 8 from the 528. How many
48 times does 6 go into 48. 8 times. Write the 8 above the 8
--- in 528. Multiply 6 by 8 and write the answer under 48, and
0 subtract from 48 leaving 0.
Let's check to see if we did it correctly. Does 88 times 6 equal 528? Yes. So we have confirmed that we did it correctly.
Good luck.
Paul
Draw a flowchart that accepts two number and checks if the first is divisible by the second
I think the big question here is how do you determine in the first number is divisible by the second number. With a calculator, try various combinations of number to see when the first number is divisible by the second number and when it is not divisible. How are the results different from when they are divisible from when they are not divisible?
Good luck,
Paul
Why are 21,25,27, etc not prime numbers?
A prime number is a number that's evenly divisible only by one and itself. 21 is divisible by 3 and 7, 25 is divisible by 5, and 27 is divisible by 3.
See Prime number Wikipedia the free encyclopedia
Is 450 divisible by 3 in fractions
450=9*5*10=9*50
9*50/3=3*50=150
To verify if a number is divisible by 3, add the digits in the number. If the sum of digits is divisible by 3, then thumber is also divisible by 3.
Sum of digits in 450 =4+5+0 =9, divisible by 3, so 450 is also divisible by 3.
1helpful
How do i factor numbers on a ti-30xs calculator
This calculator does not have a key that you can use to find the prime factor of an integer.
You can however use the calculator to find the factors
1. If number is even divide it by 2
Keep dividing by 2, while keeping track of how many times you divided by 2.
If you divided 5 times by 2 before getting an odd number, then your first factor is 2^5
2. Now try dividing by 3, keep track of the number of times you divided by 3 before you could not divide by 3 any more. If you divided 0 times by 3, your second factor is 3^0, or 1 and 3 is not a factor.
If you divided 4 times by 3, your second factor is 3^4
3. Divide by 5, until you can't any more. Keep track of the number of times you divided by 5.
4. Divide by all other prime numbers 7, 11, 13, 17, 19, 23, 29, 31, 37, 41, etc. For each prime number, keep track of how many times you divided by it, until you could not any more.
Example: 23100
Division by 2
23100/2=11550 ---------> 1 division by 2
11550/2=5775 ----------> 2 divisions by 2
Note that 5775 is not divisible by 2. No more divisions by 2.
First factor is 2^2
Division by 3:
5775/3=1925 ----------> 1 division by 3
1925/3=641. 66667 Not an integer. No more divisions by 3.
2nd factor is 3^1
Division by 5 (number ends in 5)
1925/5 =385 -------> 1 division by 5
385/5=77 ----------> 2 divisions by 5 and no more (quotient does not end in 0 or 5)
3rd factor is 5^2
Division by 7
77/7=11 --------> 1 division by 7, and no more
4th factor is 7^1=7
Division by 11
11/11=1
5th factor is 11^1=11
Assembling the factors 2^2, 3^1, 5^2, 7, 11
Prime factorization of 23100 is
23100=(2^2)(3)(5^2)(7)11
1helpful
List 7 consecutive numbers none of which is prime?
114 divisible by 2
115 divisible by 5
116 divisible by 2
117 divisible by 3
118 divisible by 2
119 divisible by 7
120 divisible by 2
17answers
Order of opertions.. directions:which operation should you do first?write +,*,-,or / 1. 25/5*8
It does not matter what sequence you write in. The sequence followed by all is BODMAS. Brackets, Of, Division, Multiplication, Addition and Subtraction.
What matters is that you should separate the * and / from + and - with the help of brackets.
How do i make my mpk49 pads work with samples, in other words, when i press the pad once the loop will play or the sample will play all the way threw, but right now when i press the pad, it only plays how...
Have a look in your manual at the sections on Note Repeat and Time Division.NOTE REPEAT] – Holding this button while
striking a pad causes the pad to retrigger at a
rate based on the current Tempo and Time
Division settings. The Note Repeat feature can
be synced to an internal or external MIDI Clock
source. [NOTE REPEAT] can function as a
latching or momentary button
19. [TIME DIVISION] – This button is used to specify
the rate of the Note Repeat and Arpeggiator
features. When [TIME DIVISION] is activated,
you can press one of the 8 switches to specify a
time division. [TIME DIVISION] can function as a
momentary or toggle button.
Please note that while [TIME DIVISION] is active,
the 8 assignable buttons will not function as MIDI
CC or Program Change switches until [TIME
DIVISION] has been de-activated.
20. [ARP ON/OFF] – This button enables and The manuals and updates can be downloaded here:http://www.akaipro.com/mpk49 Please let me know if this helps.
Nov 30, 2009 • Akai Music
k24674
ADMIN Andrew
ADMIN Andrew
