SOURCE: seeking replacement magnetron for Raymarine M92652 4kw radar
give ne an email and i will quote it
SOURCE: need outside plastic radar cover
Plastic cover as in the radome? If you still have the damaged dome the cheapest solution will be to repair it with a thin layer of fiberglass. All you have to ensure is that the fiberglass is pure and no metal shards get close during the repair.
Otherwise, give your local Radio Holland office a shout to find out if they might have a second hand dome, if not you will have to buy a new one.
Radio Holland USA, Inc.
8943 Gulf Freeway
TX 77017-7004 Houston
United States of America
T +1 713 37 82 100
F +1 713 37 82 101
E[email protected]
Also offices in:
SOURCE: JRC Radar Scanner when rotating
There is a seal on the antenna scanner shaft, just below the seal there are two bearings, thou the antenna are enclossed moisture still get inside and get to these bearings. Try and get a small amount of wd40 on the bearings, if not, you will soon begin to see false echoes on the screen because the motor on the scanner or antenna will begin to work harder causing a drag causing these echoes. Good luck.
