Thanks for your post, friend!
From what you are describing your display is showing an error code "3" on your Frigidaire refrigerator. Typically a "3" stands for your fresh food sensor has shorted. Which means the thermostat could need to be replaced or the wiring between the board and thermostat could be an issue. I would recommend you perform a reset on your refrigerator.
You can reset it by unplugging the power cord or flipping the household circuit breaker for ten minutes. If that does not correct the issue you may want to seek assistance from a professional for proper diagnosis. Hopefully this helps to some degree. -Matt
Good Morning Mark, thank you for your post!
I see that your Frigidaire dehumidifier is displaying an error code of "ES" and you would like to the meaning of that error code. The "ES" error code stands for evaporator thermistor error. This could be a possible problem with your control panel, thermistor, or a wiring harness. I would recommend contacting your manufacturer for further assistance with your dehumidifier. Best of luck! -Matt
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
