SOURCE: SINGER LIMITED EDITION-MODEL 6268
More than likely you need a pneumatic transducer. It's the part that your air tube connects to and that is what actually makes your machine run.
sewman7
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
SOURCE: NEED MANUAL FOR SINGER IZEK SEWING MACHINE
You can get a free downloadbale / printable copy by goig to http://www.singerco.com/accessories/manuals.html and cliking on the "Free Download!" button to the right of the English version description.
SOURCE: instruction manual for singer futura 2000
SINGERCO.COM
It is available at the link above for $15 - there is no longer a free download.
THanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
SOURCE: Looking for a free download of Singer Sewing Machine 6235
if you still haven't found one, reply to this thread. I have one as a PDF that I just bought for $5 that I'd be willing to share (this goes for anyone who finds this post, too)
