Has just been serviced but I let it stop and affected the chimes = i.e. llo'clock only 10 chimes instead of 11.
Move the hour hand counter clock wise to 10 o'clock. Then turn the minute hand clock wise to set the correct time.
Main Page
SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
SOURCE: How do you syncronize the chimes to the actual
Are the hands held on by a nut? usually you can remove the nut with your fingers or a pair of pliers wrapped in cloth or duct tape to prevent scratching.
Before removing turn the minute hand (minute hand only and clockwise only; do not manually turn the hour hand and never counter-clockwise) turn the minute hand clockwise until it chimes at an hour mark.
Then remove the hands and and place them pointing to the correct time.
If you are uncomfortable with this I recommend taking it to a clock shop or jeweler that sells clocks. If it is inherited, it may need some maintainence (oiling and regulating) anyway.
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
