fuses under hood
POWER DISTRIBUTION BOX
Location
Name
Amp
Circuits Protected
A
Trailer Tow
50
Fuse 32/Fuse 26/Electric Brake
B
Fan (Hi)
60
Cooling Fan (CCRM)
C
Start
60
Starter Solenoid/Fuse 30/Fuse 36/Fuse 2
D
Ignition
60
Fuse 6/Fuse 12/
Fuse 8/Fuse 18/Fuse 14/
Fuse 24/Fuse 20/Fuse 21/Fuse 27/Fuse 33
E
Rear
Blower/
RAS
60
Rear Heater Blower Motor
Rear Air Suspension
F
Seat
60
Power Seats
G
Not Used
H
Fan-Lo
40
Engine Cooling Fans
J
Power Accessory
60
Fuse 13/Fuse 25/
Fuse 1/Fuse 31/Fuse 37/
Fuse 40/Fuse 7/Fuse 19
K
Light
60
Headlamps/Fuse 10/
Fuse 11/Fuse 3/Fuse 9/
Fuse 23/Fuse 29/Fuse 35/Fuse 41/Fuse 17
L
ABS
60
ABS Control/Pump Motor Module
M
Heated
Backlight
60
Heated Backlite/Fuse 16/Fuse 28/Fuse 22
N
Fuel
20
PCM/Fuel Pump/CCRM
P
Not Used
R
PCM
15
PCM Memory
S
PCM
30
AX4S/Cylinder Identification Sensor/EDIS Module/PCM Power/EGR Control/HEGO's/IAC/
Injectors/MAFS/VMV
T
Alt./Reg.
15
Generator
U
Air Bag
10
Air Bag (Dedicated)
V
Trans. Light
10
Transmission Indicator Light
W
Fan
10
PCM Fan Monitor
X
Diode
Hood Lamp Diode
Y
Relay
RH Trailer Turn/Stop/Hazard Lamps
Z
Relay
Powertrain Control Module
AA
Relay
Windshield Wiper Speed
BB
Relay
LH Trailer Turn/Stop/Hazard Lamps
CC
Relay
Windshield Washer Pump Motor
DD
Relay
Windshield Wiper Dynamic Brake/Run
The fuses are color-coded by amp rating.
Fuse Value Amps
Color Code
Pink
5
Tan
7.5
Brown
10
Red
15
Light Blue
20
Yellow
25
Natural
30
Light Green
40
Orange
50
Red
60
Blue
