Cars & Trucks Logo
A
Anonymous Posted on Oct 03, 2014
How do unlock the child safety lock on my 2001 nissan pathfinder?
Unlock child safety door lock.
hardalada
Level 2:
Novelist:
  • Nissan Expert 279 Answers
  • Posted on Jun 03, 2015
hardalada
Nissan Expert
Level 2:
Novelist:
Answers
279
Questions
0
Helped
84533
Points
331
Open door and look at small switch type lock unlock protuberance near the locking mechanism on the door itself.....
5 Related Answers
Anonymous
  • 1861 Answers
  • Posted on Sep 30, 2008
SOURCE: door locks
Regarding the rear door child locks: There is a small lever on the latch side of the door, you can only see it with the door open. Move it to the other position.
Regarding the front door locks: You either have a bad door lock switch, or the power lock solenoids are beginning to fail. To check this, you will need to pull the door panels off, & measure the actual voltage at the solenoids whilst manipulating the lock switch. If you have 12 + VDC, I would suggest replacing the door lock solenoids. Not hard to change, but it IS time consuming. Best left to a dealer. Expect to pay 1 hour per side to change each solenoid.
Anonymous
  • Posted on Feb 10, 2009
SOURCE: child locks won't release
1997 ford explorer awd child safety won't open from the inside can you help
Anonymous
  • Posted on Jul 18, 2009
SOURCE: cant open right rear pasenger door 2005 pathfinder
i started by removing ashtray and the screw underneath. it would be easier to remove rear seat as access is not so good to move around. wind window down, then carefully pull from top of trim, it should come away fairly easy. the trim is held on by push in clips but you need to careful as they break easy. behind the inside door handle is a plastic backing plate which i found easier to remove first. now the outside handle can be undone and i simply pulled the cable and the door opened. the cable was broken where it joins the handle so a new cable is needed.
Anonymous
  • 4044 Answers
  • Posted on Oct 31, 2009
SOURCE: rear passenger side door will not open from
The child safety lock should stop the door from opening from the inside as that is it's purpose however the external door handle should open the door. It sounds as though the actuating rod has disconnected some how from the door latch mechanism. this often happens when a "slim Jim" or hanger has been used to open the door incorrectly. You will have to find a way to get the door open so this can be repaired. Your best bet is most likely to have a dealer do this as I can think of no way to access the door release parts without damaging the interior door panel with the door closed.
Anonymous
  • Posted on Apr 23, 2011
SOURCE: the battery is flat on my nissan pathfinder the
I had a similar problem. I noticed one of my door handles (passenger side) had a little key engraved on it with a small slot under it. I inserted my key into that slot to pry the cover out. Underneath was a hidden keyhole which fit the pathfinder key perfectly and opened the passenger door. I could not find this solution in the manual - so simple - yet stressful.
2answers
2006 Nissan Maxima. Passengers rear door on a 2006 Maxima will not unlock from inside.
Could be Child safety lock help prevent the rear doors from being opened accidentally. The child safety lock levers are located on the edge of the rear doors.
Child safety lock is on, how do I unlock it?
The child safety lock on the car doors is usually controlled by a switch that is located along the outside edge of the door. Open the door and look along the outside edge of the door for a small switch. This switch sets the child safety lock to on or off. The switch may look similar to the photo I've included. If you still cannot find the child safety lock, please check the owner's manual for your car.
Hi 1997 Nissan pathfinder rear door's locked, won't open from in and outside... probably child safety thing.. do you know how to open it?
Unlock all doors with the key or the key fob. Manually push down and pull up on the one door lock giving trouble. Leave it in the unlocked position and try again both with the inside handle and the outside on. If no go, you will need to get into the door..or take the problem to an expert..this will be cheaper than ripping into the door card etc. a locksmith may also know a trick or two about getting in without damage.
Could you please get back to us with the solution to the problem as this may help someone in the future.
Unlock child safety lock
try unlocking child safety switch in door jamb
Door is locked and will not open child safty lock
there is a button for every child safety lock. on the drivers door. if it is not working, then you may have to take the door pannel off and either plug the wiring back in(especially if the door got slammed hard) or go to a wrecking yard and buy a new switch for just a few bucks & replace it. Door pannels come off really easy. most pop off. some have screws. either way its an easy fix. you can do it. good luck, Tim
I have a 1997 nissan pathfinder and the side back doors wont open from the inside or the outside and the door handles seem to be broken but i dont remember them braking
You probably need to grease the doors' hardware, and the child safety lock is on. Let the windows down, and you can use a coat hanger to unlock the doors, Then lubricate the locking mechanisms on each doors' jam.
The passenger side door on my 2006 Pathfinder will open from the inside but not using the outside handle. I removed the inner door pannel but did not see anything obvious. What should I look for? Thanks!
Is it REAR passenger door?
DO NOT overlook the small switch on the "CHILD PROOF" safety switch.
This can be your problem if it's only occur on the two rear doors.
2helpful
2answers
Passenger door wont unlock, key turns in the lock but door wont unlock. Electric locks dont work. Driver door works fine 1991 Nissan pathfinder XE 4door
2006 Nissan Pathfinder rear passanger doors don't open unless opened from insinde handle first. Then will open all the time until central locking is used then same problem occurs
1helpful
2answers
Cannot get my car to lock without the keyless entry
check the room 10a fuse that is the problem
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
