The defrost timer in a Westinghouse fj383 freezer is typically located at the back of the unit, near the compressor. It may be behind a cover or housing that needs to be removed in order to access the timer. If you're unsure about locating the defrost timer or don't feel comfortable working on your freezer, it's best to consult the user manual or contact a professional technician for assistance.
You can unplug the unit & open the doors. Not very friendly to all of the items in the fridge. You can accelerate thawing w/ a heat gun or hair dryer. You will need to replace the defrost timer to prevent it from re-freezing. The defrost timer is relatively easy to replace. I recommend viewing the manufacturers' website to determine location & part number of the defrost timer.
Feel top of the compressor and tell me how hot after it has been running awhile. I need also that you advance the defrost timer=>. 216517400 Defrost Timer
clockwise slowly untill the compressor stops or starts. I need to make sure the timer is not stuck into defrost. I want you to leave the compressor off for up to 35 minutes. If the freezer compressor doesn't restart bt then simply again turn the timer clockwise slowly until it does and then stop turning. The defrost timer is location 23 in this photo HERE If you need to turn the defrost timer like this to restart the compressor then replace the defrost timer and this will resolve the freezing problem. If not we move to the defrost heater location 14 in the sme photo=> 216254600 Defrost Heater
I am going to stop here until I hear from you, Thanks Sea Breeze
check the timer maybe your Fridge it has timer to defrost or is set to auto defrost try to make set to manually defrost..or if you have manual of that item read it for guidance..
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow. You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model thumbs up
The defrost timer is normally located in the area of the temperature controls. There is a clutch head knob on the timer which can be rotated clockwise very slowly until a click is heard. Wait 30 minutes and defrost should take place in that time period. If defrost does occur and the system does not restart cooling, rotate the knob more and you will hear a second click and the compressor should start . If the system restarts in the cooling mode in 18-22 minutes the defrost timer is good and the problem is more than likely in the defrost heater circuit.
