Question about Dell Latitude D610 Notebook
Error code 1000-0416 and 1000-0141
Laptop won't start up. All I get is a the black screen (We apologize for the inconvenience...) I try to start in Safe Mode, but can't. Ran DST and got error codes 1000-0416 and 1000-0141. Laptop worked fine last night, but not today.
    Problem Solver:
  • 18 Answers
Those errors indicate a hard drive failure. I would replace the hard drive.
Posted on Oct 04, 2014
    Sergeant:
  • Dell Expert
  • 464 Answers
Answer: Bad Hard drivr
DST stands for Drive Self Test thats why your getting the 0141 error. The code 1000-0146" "msg: Unit 2: DST Log contains previous errors. Thoses errors are stored in the Bios.
Look for an option in BIOS Setup to clear the error log, or try turning error reporting off in BIOS setup, then reboot and after 2nd reboot turn it back on.
If you don't find either of those options, clearing BIOS should clear the error. But before you do that, open BIOS Setup and copy down all the current settings. When you clear BIOS, you reset everything to factory defaults, which may or may not be suitable for your system configuration.
So after clearing BIOS, reboot and open BIOS setup again. Confirm that all settings match what you copied. If you make any changes, be sure to save them before exiting setup.
  • Dell Master
  • 3,866 Answers
These error codes lead me to believe the video card that is on the motherboard has called it to quits. You could investigate how much a logic board for this would be, I found ebay to be a good source. This is not one of those quick fixes it will need to be taken apart. Should you worry about cost, I would be shopping for a new laptop
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE:
mayviller
  • 41 Answers
SOURCE: It Keeps restarting at the loading screens
The error refers to a bad Hard Drive. You need to call up Dell to have the Hard Drive replaced. Make sure to start contacting a Local Pc Shop to help you back up files from your Hard drive since Dell doesn't cater to backing up of data on any Hard Drive.
Posted on Oct 02, 2008
SOURCE: Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Posted on Mar 16, 2009
sabharish
  • 297 Answers
SOURCE: Dell Inspiron blank screen
You can restore your system in your safe mode.
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Posted on Jun 11, 2009
shadow83
  • 496 Answers
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Posted on Oct 14, 2009
  • 3940 Answers
SOURCE: i have a dell studio 1737 laptop i purchased in
0F00:065D is a hard drive read test failure. the hard drive is failing. If purchased in Feb, the system should be under warranty call Dell Tech Support to get a replacement hard drive. (800-624-9896 in USA)
If out of warranty you can get a 2.5 in SATA HDD at Newegg.com for about $60
Posted on Dec 05, 2009
My computer won't open windows.
Start the system with safe mode and uninstalled the recent hardware drivers may solve your problem.
Revert back for more assistance.
Jan 26, 2010 | Dell Inspiron 1501 Notebook
It wont start up kind of
Try start, run, then type MSCONFIG go to start tab and UNcheck everything, then go to services and at the lower left of the window it says hide microsoft services and check the box then disable all then restart and see if that helps.
Sep 02, 2009 | ASUS Eee PC 1000H Laptop
Toshiba Satellite Laptop M35X-S167 - Windows Won't Start
Please try re installing your operating system. (Genuine windows xp or vista recommended)
If the problem still persists feel free to get back me @
deepuunni1985gmail.com
Jul 19, 2009 | Toshiba Satellite M35X-S349 Notebook
Black screen white writing...
Restart and keep pressing f8. Select safe mode and see if you can login to safe mode. If that is not possible then keep pressing F10 key to start recovery tools. Just follow instructions on the screen in recovery tool to recover your Notebook back to factory settings.
If there is any important data on the notebook, then use data backup tool in REcovery utility.
Please leave your feedback if issue was recolved
May 27, 2009 | Compaq Presario 900 /1500 Series EVO...
HELP! Laptop will not boot up!
Try an XP repair:
Boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 10, 2009 | Gateway 3550GZ PC Notebook
Help!!!
Try reinstalling windows. Before installation it will show you an error type that error in google and then you should have your answer to your problem. before that i suggest you check your ram cause this problem appears usually when ram is damaged.If damaged remove it and buy another one
Jul 07, 2008 | Computers & Internet
Dell Latitude D610 Notebook Logo
242 people viewed this question
Ekse
Clive
Clive
