On Ubuntu 14.4
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
SOURCE: Lexmark E238 prints about two thirds of a page and stops
Please follow the instruction given in this link:
clear the paper jam as given in this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=37:1:0:512:0:0&framed=&docid=ENUS25568&relevance=1
SOURCE: Prints a blank page only
First try to clean the cart with following procedures if this did not work then heat walls of the cart with hair dryer for 3 to 5 min then insert the cartridges and try to print :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
SOURCE: Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
