no engine told. size, this tells what transmission sites behind it.
1999 Dodge RAM 1500????? not VAN. 1500
2wd or 4wd'/
5 engines. then.
check all fuses, some have stand alone TCM brain (tranny)
scan the PCM for P07xx error (tranny)
check ATF levels
hot, park ,idle, only do not overfill it ever.
ATF+3 (not sure but do check)
they used 3 transmission then
4-speed
42RH-RE automatic
4-speed
46RH-RE automatic
4-speed
47RH-RE automatic
42RE , is electronic shifted,
OD gear is dead or just the TCC lockup deaD
best is count the gears more carefully to see truth.
yes 4th gear is OD Geared. 3rd gear is 1:1 lockup.
.74-to-1 for first, 1.54-to-1 for second, direct 1.00-to-1 for third and 0.69-to-1 for fourth.(OD)
scab the PCM
to see if errors from the transmission show up.
I bet they do.
the 3>4 shift solenoid must work, .and no pressure errors.
the schematics show an OD switch if not closed OD does not happen, forget about that switch>
if car is 4wd and is in 4wd, many cars/ and truck all shut off
OD in 4wd, by logic inside the PCM (pure) my not be true on the biggest engine not told.
