SOURCE: MY CUB CADET LTX 1040 IS PROBABLY A 2009 MODEL.
The problem is most likely the interlock safety that prevents the riding mower from running when no one is seated. There is an interlock switch in the seat. Either the switch is defective or you have a break in the wiring between the seat and the rest of the system. Did you disconnect any wiring connectors when removing the deck? Did you get them back in the correct locations?
Jim
Preston Comptuer Services
www.prestoncomputerservice.com
SOURCE: cub cadet model LT1050, when
I believe the problem is a safety feature which is connected through the RMC, like the seat switch, just do a search for RMC on this PDF Manual it will show you how to check and what does what, Hope it helps and Good Luck Tim:
http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02100.pdf
SOURCE: Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
SOURCE: cub cadet riding mower wont start... parking brake feels loose wont turn over
see if the rod fell off there is a safety switch on the clutch/brake pedals if the rod doesn't move all the way the switch will not make the connection
SOURCE: cub cadet 2166 dies when I engage PTO or let brake peddal all the way up
replace that safety switch there is two switches built into one
