How do I disable/disconnect the fax facility on a MX536? The fax cuts in to every incoming call on my landline.
Easy answer is to disconnect the phone line from the machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
SOURCE: how can I get rid of the Fax facility.
click start / settings / printer and faxes. once there delete the fax icon.
SOURCE: I cannot recieve fax
You change your distinctive ring to the correct pattern like double or triple. Go to Setup and select advanced fax setup then select distinctive ring...
it should work!
