Panasonic KX-T7736 Corded Phone (KXT7736) Logo
A
Anonymous Posted on Oct 02, 2014
<!-- from fixya rte -->Mute button is not working - Panasonic KX-T7736 Corded Phone (KXT7736)
1helpful
How to fix + and mute buttons on steering wheel
you can buy the switch from the dealer and they change very easy
Ignition off radio works, ignition on radio mutes
i would also check the mute or volume buttons on the steering wheel. spray them with a can of compressed air, hold the volume up and spray the minus and vise versa. hope this helps.
1helpful
Was working ok then went mute - is there a mute button
If there is a mute button, it will be on its remote control. There will be no Mute button on the device.
1helpful
I have an HD remote control and the mute button doesn't work. Can I program it to do so?
When your all other buttons work only the mute button doesnt work.The problem lies with the mute button only.Not with programming.
Thanx
My volume and mute button has stopped working all other buttons are functioning properly
Press the mute button and then turn up the volume button. If no sound still then press the mute button again. If we are talking about a Remote, then change the batteries.
2helpful
Mute button not working to lock out phone
take out your battery and put it back in. let it load up completly and see if it works. press and hold the mute button
2helpful
How do I mute my MLS-34D when using Speakerphone?
5104,
The button that mutes the speakerphone is the mic/HFAI key located above your speaker button. The mic mute feature works while using the speaker, when the phone is idle it works as the handsfree answerback intercom.
hope that helps,
Prescario v6000 mute buttons and sound button dont work
you have to install the driver
get you driver driver through hp site
Mute - Turn On??
Welcome to Panasonic :-)
The mute button works when you have a speakerphone call. That means SP-PHONE pressed and press MUTE and it flashes to let you know it's on mute.
Maybe software version 9.0 will fix the mute to work on handset calls.....
Carl
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
