Briggs & Stratton 6250 watt portable generator Family 3BSXS. 3422 HT 275385
You will need what the factory resistances valuea re supposed to be, cold. Then use a high quality ohm meter with 3 decimal places, disconenct all wires off the stator. Check each wire with a meter to the ground frame, if there is any value, stator is shorted. Then check between stator wires ie L1 L2 and compare resistance value with factory values.
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
