Its a 26hp kohler engine with hydrostatic trans.
SOURCE: craftsman zts 7500 will not run with levers engaged
Cody,
Yes, I am sitting when I do engage the blades on my craftsman zts 7500. All you do is pull/push the engaged button to your left well you are seated.
SOURCE: craftsman mower with 26hp kohler smokes when i cut on hill, why?
what happens is the oil gets into the valves which will come out the exhaust when on level ground after a side to side or going straight down because the valve's are in the front of engine which is pointing to the front of mower you wont hurt the engine if it does that i would just check the oil often to make sure it doesn't run out
SOURCE: I have a craftsman zts 7500 zero turning radius 26
i going to assume that yr tractor does have the hydrolic p.t.o. that controls the drive and cutting mechanism's???... if so you might start with checking the hydrolic fluid in the resevior. or you might check into replacing the hydrolic p.t.o. pump , if you ran the tractor in heavy work without any hydrolic fluid in the p.t.o. pump the pump is probably burnt up. if so im sure you can beat the cost of a new pump by rebuilding it yrself with a kit.
SOURCE: Craftsman mower with 26hp kohler smokes while cutting.
it sound like you put to much oil in it.if not check vent valve
SOURCE: My craftsman zts 7500 will not start.
The problem may be one of the safety switches. Make sure the blades are not engaged. The clutch pedal needs to be pushed all the way down, and there is another one that needs weight on the seat. Look around those areas for disconnected wires. Some even need to be in neutral. Lots of safety features.
