The problem is in the inside of ypt310,nothing to do from outside.
Is it after the unit is turned off, and then revived, this conditions happen again?
If the unit still can play for a minute/moment, the damage is usually located on the regulator. There may be a capacitor/resistor/ic damaged by heat. When there is not hot, the regulator is working normally, and the unit was normal. But after a while the heat turned up (at component parts), the regulator becomes abnormal / unstable, and the unit is turns off.
There may also be damage in the other section, which causes the regulator gets hot. If you are not experienced in electronics repair, then leave it to the experts.
Try also, check the wiring-connection from regulator to another board (usually using the socket, it may loose its socket)
