Fan housing screw seams to be stripped
I do not know of any screws that would be stripped right at the fan. Here is a walk through on removing and replacing the fan, the shaft needs to be turned counter clockwise.
Kirby Fan Replacement
800-775-6586
GoodVac com
SOURCE: Kirby Heritage 1HD
this site may help
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
good luck :)
SOURCE: Fan replacement
I'm assuming you mean to replace the impeller fan...if so this site has step by step instructions...
hope this helps!!!!
SOURCE: Kirby Heritage 2 fan replacement
Take the bag asm. and handle off. Then remove the plastic strip covering the switch, remove the screw there, remove the 3 screws on the housing, turn it over and loosen the screw near the back, the housing should come off. Then remove the screws on the back of the fan casing. You shouild be able to get to the fan, hold the fan and turn the spindle to the right to take off. If it would turn off, then you may have to lock the armature so it can't turn to move it. Then re-asemble in reverse.
SOURCE: replacing the fan hub on a kirby classic omega 1CB
I resolved the problem .I found a way to hold the armature shaft still while I unscrewed the pulley drive nut ,which must be removed in order to remove the vacuum fan.
> There probably is a special tool somewhere that would fit over the armature ( the metal part that spins on the shaft of the motor inside the stature) to hold it still ,but since it was suspiciously omitted from the rest of the fan blade parts ,I had to fabricate one myself.
>I happen to have three ,steel blade ,broad paint scrappers which were about 2 to 3 inches wide and thin enough so there blades fitted nicely into the groves that run the length of the armature without damaging it, as would be the case with a narrower screw driver blade .
>Bracing the handles of the 3 scrapper blades in a slot that was in the side of the case ,which was probaby its' intented purpose, held the armature shaft still while I unscrewed the fan nut which happened to have a reverse thread.( turns clockwise to loosen) .
>It unscrewed with ease. Problem solved!
SOURCE: replace Kirby legend II fan
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
