Grundfos MQ3-45  1 HP Pressure Booster Pump  Logo
F
Faith Kalei Posted on Oct 02, 2014
My grundfos mq3-45 is making high pitched electrical noise. otherwise working well. recent power outage
Making high pitched electrical noise
Nosey new refrigerator has high pitch or low noise irritating
is it an inverter fridge which saves on energy. that makes a high pitch sound. i recently fell into the same trap. if it has a clock set the time so its more inclined to make those noises when you are asleep.
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Clothes Dryer makes high pitched sqeak
Most driers have to be disassembled from the back and work your way forward. Try that.
Hello I have a Grundfos circulating pump #UP1542F on my system. It recently started making this high pitched whistling sound for about one minute than quits. It seems to only do it on start up / when
I do not know your system but It sounds like a restriction forming in the system. It may be calcium deposits or a valve not closing properly.
Nov 22, 2013 • Plumbing
2answers
1helpful
2answers
Power outage occurred. Upon power back on Dishwasher has high pitch tone and no lights and it will not do anything but make sound.
A power surge has occurred unfortunately. this surge has fried the control module and, you will need to replace this module asap.
I would check the motor as well. it may have took a hit as well. test the continuity of the element as well.
Wont turn on and high pitch noise
Looks like the printers internal electrical components have gone. if there is a tranformer in your printer then that is making that noise. or else even the motors might also be gone.
my strong suggestion take it to any authorized service personnel
2answers
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Panasonic TV
The power surge has caused a failure of an internal component. If it is making this noise it is possible the line output transistor has failed. I would advise calling a service repair centre & have someone there take alook at it. All being well this may be the only problem. Power surges can sometimes cause other faults.
Top Grundfos Garden Experts
john h
Jay Finke
Jay Finke
ADMIN Eric
ADMIN Eric
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
