look at the top. there may be an access thingy you can remove to get to the lightbulb. replace the lightbulb with suitable replacement. problem solved.
The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
Also at
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you don't find yours,
or if you want to look at it without disassembling the oven, you can
download it here.
You can find
helpful exploded view diagrams and order parts by entering your full
model number (KBMC140HSS0, KBMC140HSS02, KBMC140HSS03, KBMC140HSS04, or KBMC140HSS05) here.
That model would be KBMC140HSS0 *(zero not "oh") and there should be one last number on the end. Check the tag in or on the unit for the full model number.
Your membrane assembly is shorting, and it will be one of these part numbers, depending on model / color:
4453028 Black 4453029 White 4452882 Biscuit 4453025 Stainless
You can find links to helpful exploded view
diagrams and part ordering help
here.
I recommend that you bookmark that
link to your favorites.
We're
You
can download owner's manuals and installation instructions for
several brands (including Amana, Jenn-Air, Kitchenaid,
Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
We're
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
