Not sure on the model number. sorry I tried to record hd programs direct from the tv to a brand new USB and it says that there is a usb error & no device for TV Recording. How can I still use the usb for direct TV recording?
SOURCE: Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
SOURCE: DVD Recorder
If you connect a time base corrector box in between the device and dvd recorder, you will have no problem recording anything
SOURCE: After recording a one hour episode, won't recognize the dvd.
Try inserting your DVD media into the PC and doing a 'quick format'. The LG is not seeing what it considers to be media that it can use. It is not seeing that you have inserted recordable media. Sometimes you can reformat the DVD or do a quick media erase, and the LG can then put on its blank "squares" that is uses for its menu selection. I think that it what it does when it 'initializes' a new media.
tom
SOURCE: How to Record TV Programs w/o Cable Box/Satellite Receiver?
Ok, I had this issue. And this is what you need. Even if you have a new HDTV, you need a converter box. The new TVs are not made to send out the signal just take it in. Best price I have seen on converter boxes was H.E.B
1. Antenna to converter box
2. Converter box to VCR
3. VCR to T.V
You will have to leave the converter box on when you are recording or leave it on when you leave the house. Also it has to be on the channel you are recording and the TV needs to be on channel 3 or 4. When you program your VCR it needs to be for the time and stuff. But put it to record channel 3 or 4. Which ever you pick for it to record off of. It really is easy. But I do hate that the people that had this great idea made it to where we can only record from one channel. I am going to try to send a diagram that I drew. Not the best artist, but you can tell what I mean. I can not seem to get it to attach the attachment. But you should not have a problem. Good Luck :-)
SOURCE: Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
