Drum makes banging noise
GOD IS GOOD !!!!
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
SOURCE: dryer makes banging noise
basscat, you first remove the door by removing the screws from the hinges. The door will lift up a litte and pull off. Next remove the spacers on the other side. Now the front panel will pull out from the top. There will be two 1/4 inch screws with latches on each side of the frame, remove these and the top will lift up. Now by holding the door switch and starting the dryer, you will be able to see what is banging. Once you determine that, you can remove the bulk-head, should be 4 screws, be sure to unplug the door switch. Unfasten the belt, remember the configuration and remove the drum. You are now able to get at the insides. Catriver..post back.
SOURCE: whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool
dryer to be noisy.
To find out what is causing the noises, you
need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to
pinpoint where in the dryer the noises is coming from. Once you have
an idea of the area, you will need to disconnect the dryer from the
wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your
dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of
the drum, in other words, the baffles job is to separate the pieces
of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot,
the drum baffles holding screws will become loose. Loose drum
baffles will cause noises. All you need to do, is to open the top
panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the
front and two on the rear. The job of the drum support rollers is to
keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start
to make squeaking noises and the roller bearing will start to wear
out until the bearing on the roller is gone. When the bearing on the
roller is gone, the noise will change from squeaking to a clanking
noise.
The blower wheel:
The blower wheel is use to circulate the air inside of
the dryer drum. The most common Whirlpool blower noises are cause by
something falling inside of the blower housing and hitting the
blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on
the belt. There are two types of idler pulleys, the pulley with the
wheel and the pulley with the teflon slide. A bad idler pulley could
cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to
run kind of noisy. When the motor starts making noises, the solution
to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These
belts work very hard making the drum tumble. When the belt stretch
just 1/2 inch more that it supposed to, the belt will start slipping
and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become
noisy in your dryer. When your dryer starts making noises, make sure
to check it out before it gets worse.
SOURCE: Dryer has a banging noise
It Is fixable.All you need to is try to balance the load or a perfect concrete flat surface for the machine.
If
the problem still persists, then during the previous vibrations, the
shocks or the drum bearings might have been damaged, you might have well replace them to
avoid further problems.good luck.and please post your comments.
SOURCE: my Frigidaire dryer makes a banging noise
What you have here is a drum bearing issue. Read my award winning essay on this subject right ova HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: hotpoint tumble dryer making a banging noise, is
This could be a simple fix or more of a major task, so if you think you can have a go then great, first find tools and torch, empty any clothes, unplug from the power supply,disconnect vent if any, place unit on a table or bench then remove the back check for large quantities of fluff and dust, clean as much as possible, see if drive belt is secure and not damaged if this is not the case then the drum bearings may be worn, try to move the drum up and down, try the same thing from inside the door, as these dryers tend to wear front bearings quicker than rear ones, if excessive wear and you are confident, remove the drive belt and tensioner take note of the layout, remove supporting bracket at rear of drum taking careful note of where any nuts bolts are from, withdraw the drum you should now have access to all the bearings which are usually like a special plastic runners or ring, contact local supplier stating make and model number ask for a bearing kit, replace bearings and rebuild machine, all this could take up a few hours to a few days so ensure you can manage without a working dryer.............good luck
