SOURCE: how do you operate Bella mod
there is an on/off switch right below the seat next to where you plug in the charger, then you have to twist the right hand grip
SOURCE: razor bella problems
Most likely a bad battery. Check out put voltage on all posts. If it's 12 Volts DC or more, then it should be ok, and you'll need to start looking in the wiring such as the speed control switch. If not, your problem is a bad battery cell and you should replace it. NEVER TRY TO SERVICE A BATTERY!!!!!
SOURCE: where is the reset button at on the razor bella scotter?
there isn't one, but there are fuses by the battery that can be replaced
SOURCE: Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
