Oreck Cordless Speed JP8100CA Iron Logo
A
Anonymous Posted on Oct 01, 2014
<!-- from fixya rte -->Green light flashes and not heating - Oreck Cordless Speed JP8100CA Iron
2answers
Oliso iron green light flashes but does heat up
You would have to take it apart and check the following in this order with a multimeter.
Element continuity.
Switch operation.
Thermostat.
Wiring plug to internal junction terminals
Feb 04, 2022 • Oliso Irons
The green light keep clicking on and off
That is the normal way of operation. The green light comes on when the iron is heating up and when the temperature is right the thermostat switches off power hence the light going off.
1helpful
Tefal Pro Express GV 8120 Iron. New Iron - will not heat up and turn itself on. Green light just keeps flashing.
If it is a new iron, take it back to the dealer. Any attempt to repair or adjust on it will void the guarantee.
2helpful
2answers
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
My iron lights up. when i set the heat choice the green lights on the right flash and it does not heat up
Generally, the lights on the right flash until the desired temperature is reached. When they stop flashing it means the iron has heated to the temp. that you selected. I'm having trouble with mine now, also, so I can't diagnose.
2helpful
I have a steamglide 2200 iron with water tank, it won't heat up. I have tried with the tank full to max and halfwy but it still won't heat up. There is a green flashing light on the side of the base with a...
sir, this is the rare problem. you need to replace your iron's heating coil. due to this these type of problem arisses.
thanks for contacting fixya
Sep 12, 2009 • Irons
4helpful
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 • Irons
Iron won't heat
send me manual on iron g1490
john reilly, 5640 hwy 14 w janesville wi 53548
asap
thank you
3answers
Its gone off!
The green light indicates the unit thinks it is out of water. Take of rewervoir; make sure the inlets are not plugged. Open the little plug on side, clean tank w/ clear water only, and shake out all water completely. Put it all back together, but leave reservoir off. Turn on and run unit "dry". Your should hear a "flutter" sound as the unit trys to pump water from missing reservoir, the heater/steamer should be sizzling hot & pressurizing. THEN the green light if ome ON, asking you to switch it off, refill & install the water reservoir. If things don't happen in that sequence, you should be able to determine what is wrong.
Top Oreck Irons Experts
ZJ Limited
ZJ Limited
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you an Oreck Iron Expert? Answer questions, earn points and help others
