Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
How do i replace hidden bake element in frigidaire range
  • 1,555 Answers
Unscrew all parts and lay them out on the garage floor. Scatter them and mix em up good. When done, try and figure out what goes to what. If you have parts left over when done reassembling; just toss them out.
Posted on Dec 10, 2014
SOURCE:
  • 833 Answers
SOURCE: Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Posted on Dec 13, 2007
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
Macmarkus
  • 2605 Answers
SOURCE: Frigidaire Gallery Range m#FEF389CFBK. The heat
Hi, If I was being called out to look at your range and you described to me what you said in your post, I would definetly bring an element. I suugest you tell that to your service person or purchase a new element. That is quite often the way the element's burn out, just as you described...a sparkler. Hope that help's. Good luck and thank's for visiting fixya. Macmarkus :)
Posted on Dec 11, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
  • 949 Answers
SOURCE: my frigidaire electric range had a f1 code come
The F1 code is a failure of the ERC (electronic range control), the only fix would be to replace the control board.
Posted on May 17, 2010
How do I replace the lower (hidden) bake element
http://www.appliancepartspros.com/parts-for-frigidaire-fges3065kwa.html exploded view
Dec 29, 2015 | Kitchen Ranges
Gr673lxss 1 how to find hidden bake element
Kyle,
Usually what they mean by "hidden" element means that the bake element sits in a recessed part of the oven cavity. You only have one bake element and one broil element in the oven. Hope this helps.
Mar 13, 2015 | Whirlpool Electric Range
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The Bottom oven element has burned out. Is is
It's replaceable,if it's an exposed element meaning you can look in the oven and see the element you can do it yourself unplug the range take out the two screws securing it pull it slowly toward you,unplug the two connectors and put in the new one,if it's a hidden bake meaning you can't see the element you would be better off having it done.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cooking element
You do not list a full model number. Typically a JBP78_____ uses a WB44X10013 bake element. Disconnect power to range. Take out two 1/4 inch hex head screws holding element in at back of oven. Pull element out a few inches into oven. Disconnect wires. Reverse to install. Not too hard if it is an exposed element. A bit more involved on ranges with "hidden" bake elements (which are under the floor of the oven).
Oct 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
Frigidaire oven not working in bake setting
Hi Thanks For The Question. I Would Check The Bake Element. Replace The Bake Element .Thanks The Appliance Doc
Oct 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Apr 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
360 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
