Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
A
Anonymous Posted on Oct 01, 2014
What is the correct bobbin for my Brother XL3200
What bobbins fit a js1410 brother sewing machine
Brother lists the correct bobbins for the JS1410 on the consumables page for the machine: https://support.brother.com/g/b/colist.aspx?c=ae&lang=en&prod=hf_js1410eas&cao=hfgsacc . That labels the bobbins as the SA156/SFB. These are also called Class 15/A bobbins, https://sewingsupplywarehouse.com/js1410.html .
I hope this helps.
How do I lower my feed dogs on my Brother XL3200 sewing machine?
The Brother XL3200 does not have an option to lower the feed dogs. It came with a darning plate, part number XA3443151, to cover the feed dogs. This is available at Amazon.com for less than $10, including shipping. See https://www.amazon.com/Brother-Darning-Plate-XA3443151/dp/B002EZVSUU . It's also in stock here: https://www.sewingmachinesplus.com/pd60-XA3443151.php .
The manual for the similar Brother machines, XL2600 and XL3500, show using the darning plate on page 38. This manual is available here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_2600_2610_3500_3510_EN_206.PDF .
I hope this helps.
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Tension problem. bottom thread loopy.
Make sure the bobbin is the correct one for the machine first. Try another bobbin on a scrap of material. Bobbin will fit into the bobbin holder going the incorrect way. Make sure the thread is unwinding in the correct direction. mine has a arrow for the correct position. Hope this helps.
1helpful
Winding bobbin problem Brother NX200
the machine should be checked to see if there is something wrong with the bobbin spindle..
1helpful
Why is my brother sewing machince lower thread tangle
try changing the needle
try a different bobbin
make sure the bobbin is wound correctly and not over wound
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
make sure the top thread has not come off the thread take up lever
Brother PE 180 D WILL NOT PULL UP BOBBIN THREAD
change the needle--make sure it's the right one for the fabric being
sewed
rethread the top thread make sure to use every thread guide
also make sure the bobbin is inserted correctly into the bobbin
case
also make sure it bobbin is wound correctly, that it's not warp
it's also possible that the machine could be out of time
I have brother xl3200, can i free motion sew on that?
can you drop the feed dogs on your machine ? if you can then you can
Top Kenmore Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
