SOURCE: I have a Braun thermoscan type 6022, but code po5
It's not po5, its pos... you're not positioning it properly in the ear canal.
SOURCE: Can you change the temp
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
SOURCE: I have a Braun ThermoScan Type6013 have changed
Problem:
Temperature taken is not within typical human temperature range (93.2 °F - 108 °F / 34 °C - 42.2 °C).
Solution:
Make sure new, clean lens filter is properly inserted. Then, take a new temperature.
