I will take a shot at this question, only because I had a similar problem this past spring. You probably have everything hooked up correctly, the pump, the shaft key, and everything else the way it should be. If the unit sat for a while, or a long period of time ,it may have built up some rust , at the nozzle end. I will assume that your pump comes on and no water comes out of nozzle. If this is so remove nozzle and look through the small hole in nozzle. If you don't see light this is most likely your problem. Take a small piece of wire, or a pin and push it through. I had a nozzle clog on me this way. I didn't think this could happen till I started to diagnose down the line. Please get back to me with your results. GOOD LUCK FREIND.
The mechanical engineer in me just had to solve the problem. I unscrewed and removed the bottom plastic cover (3 screws) where the power card goes into the machine and found the problem. The water from the reservoir feeds into a white plastic priming pump. This priming pump is assembled in two halves and one half has four plastic clips that hold the pump together. In between the two halves is a rubber o-ring. Well, one of the clips was not secured and I could see part of the o-ring protruding. This is an obvious source of leakage. Either the pump was not properly assembled or it snapped out of place during shipping.
I unscrew the two screws that hold the priming pump in place, leaving the hoses attached, and carefully pulled the two pieces apart. Note how the magnetic impeller is installed and reassemble the same way. Use a small amount of vegetable oil to lubricate the o-ring and reinstall in the same place. Reassemble the to two halves, making sure the o-ring doesn't protrude, then snap the two halve together tightly. Screw the primer pump back into place then screw the bottom plastic cover back into place.
After this fix the machine no longer leaked and it brewed a nice espresso. Everyhing seams to work find now.
shipping.
