Occasionally the water will just keep boiling and not turn off. This is very dangerous as the water can boil dry and shortcircuit the kettle.
In my case, it's usually the lid not being closed properly. The steam escapes, instead of finding the shutoff thermostat switch, so it boils constantly. Eventually it would boil dry, which would cause the heating element to fail. I usually tap the lid down a bit extra just to make sure.
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
SOURCE: kettle lights but doesn't boil
Most likely the thermo fuse is blown.
You have to take the kettle apart and see the spec for the thermo fuse. You can get these at most any electronics parts supplier for appliances.
To change the thermo fuse you will need the proper crimp type connectors and the crimp tool. This is not able to be soldered. It runs too hot, and soldering in a circuit close to a heating element is not able to be used.
Before changing the thermo fuse, you can test it with an ohm meter. It should typicaly read about 0.1 to 0.2 ohms. The heating element resistance should typicaly read about 8 to 12 ohms.
If the heating element reads below 6 to 7 ohms on a well calibrated ohm meter, or above 15 ohms, it is defective.
If the thermo fuse is blown, the kettle may have been left running when boiled out and over heated, or there is a short in the heating element.
If you feel that you are not comfortable to do this type of repair, it would be best to give the kettle out to an appliance service centre to have it serviced.
When you change the thermo fuse, and if it blows again the heating element is probably damaged. It must be replaced if possible, or if worth the cost.
On the other hand, if the kettle is more than a few years old and you don't want to go to all this trouble, you may want to consider to simply get a new one.
Jerry G.
SOURCE: Boiling
Purchased at Canadian Tire mid December 07.....great sale....still more than I expected to spend on a kettle. EE and nothing.....same as previous customer comments.
SOURCE: Breville spectra kettle, light flashing- cause unknown?
It could mean that the warming element is defective; open.
SOURCE: filter for breville kettle jk155
Contact Breville on 0161 652 1211 and they will mail out one
SOURCE: my kettle does not turn off when boiling
this is more likley to be the switch its just a bimetallic type,when it gets hot steem on it it flicks the switch to turn the kettle off try giving it a realy good clean up inside around the switch it may just be lime scale blocking the vent hole
however normaly when the switch playes up its a new kettle
