Garmin Nuvi 660 GPS Receiver Logo
A
Anonymous Posted on Oct 01, 2014
<!-- from fixya rte -->How do work stoped gps garmin - Garmin Nuvi 660 GPS Receiver
Muhammad Farooqi
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Oct 17, 2019
Muhammad Farooqi
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
2803
Points
14
I had the same issue, i'm still using in 2019.. and all in Sudden no signal started appearing.. I tested all possible methods, but none of them worked.. today in morning, I opened my garmin's GPS module, and the cable was out form the circuit.. I fixed that back and wow.. it worked great.
You should have tried this too.. like open the garmin screen, and then check if cable is fully afixed or not.
How come my garmin nuvi GPS JUST stoped working ?
Try a master reset, try powering it overnight, try plugging it into the computer. If none of those work then replace it. How come... well howcome car tires wear out, how come cellphones only last a few years, how come you aren't still using cassette tapes? it's technology, it dies and gets old just like everything else... is it in warranty? awesome! otherwise replace it or call the manufacurer to see if they fix it for less than replacing it.
1helpful
My GPS stoped working sudenly
get it on to charge for atleast an hour and then connect it to garmin.com through ur PC. Pls click updates and see if any update is available to install. install if there is any. and try to turn it back on.
My GARMIN 350 has stoped giving me street names. just "turn here"
Please try this solution first. It sounds like you don't have any TTS (text to speech) voices selected.
http://www.sharc.net/discus/messages/6/74.html?1269626536
- Jim
2answers
Automatically turning off after warning message
normally it's a sign that your battery is shot, should never leave them plugged into the car when not in use
My nuvi 765T dosn't want to turn on even if i charched it it doesn want to turn on
Sounds like your battery may need replacing or there is a internal problem. If you noticed it running shorter and shorter on the battery then I would assume its the battery. If it suddenly stoped then the main internal board. Garmin is great for support so give them a call and they will get your sorted out.
I have a Garmin Nuvi 680 and the touch screen stoped working.
The touchscreen needs to be replaced. Please see this link which explains why this happens:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
I tryed to down load numaps lifetime on my garmin
I was just going to the wrong place on the home page. I finely got it down loaded last night.
2answers
Garmin street poilot i3
If using rechargeables try high rated ones or better still new alkalines to see if the problem still occurs.
2answers
GArmin Nuvi 360 - bluetooth not working right
Wow, as soon as I got my nuvi 360 I turned the Bluetooth off. I then updated to 4.40 and the bluetooth SW version is now 0.00 and i cant even enable the bluetooth again. I think we have the same problem. I wish I could help but I am in the same boat.
Touch screen stopeed working
The wiring going around the digitizer screen is broken. Find a dead unit on Ebay (hopefully one with a good screen) and replace the screen. But with the cost of the Nuvi 200 under $200 and refurbished C330 for under $150, it might be time to replace the unit.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
