Question about Hoisting
What dose a black/ gray female bullet wire connect to on a 86 Mustang GT 5.0 HO cant find the male wire to plug it in to its bye the main cp passenger side floor ?
5 Suggested Answers
SOURCE:
  • 1596 Answers
SOURCE: black/blue ground wire
Both are BODY Grounds
Posted on Aug 05, 2009
BaronVonNuke
  • 1915 Answers
SOURCE: I need the wiring diagram
The wiring for PS2 connecters is standard.
Here is a link
Posted on Mar 24, 2011
pctech1
  • 1940 Answers
SOURCE: I have a cub cadet
Here are all of the Cub Cadet Wiring Diagrams from Cub Cadets website: http://www.cubfaq.com/wiringdiagrams.html
From your description, this almost matches the Original Cub Cadet wiring, but there are a few differences. Here is the wiring diagram: http://www.cubfaq.com/wiringdiagrams/original.jpg
The Cub Cadet 1200 and 1250 have the same wiring diagrams, but they are different from what you described. Here is the wiring diagram: http://www.cubfaq.com/wiringdiagrams/1200.jpg
I also found the Cub Cadet 125 to be somewhat similar to your description. Here it is: http://www.cubfaq.com/wiringdiagrams/125.jpg
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Apr 12, 2011
gopakumarg43
  • 76140 Answers
SOURCE: Page E-11 of manual, "Connecting
Hello
Take [+ and --] of each channel as input for Left And Right. That is take two [+] wires of two RCA wires to Left and Right channel input. Short two [-- s] together with screen and it is the common ground. Connect the two [+] wires to two end mins of 5-pin Din, ie, left and right channels input. Connect the two [--v and screen together] to 5-pin Din's center pin. It is the ground pin. If you have any doubt about the ground pin of the amp. check it with a mutimeter. Grond pin will show continuity with the chasis. OK.
Posted on May 26, 2011
Model gw711. Where can I get a wiring diagram?
beside the main power plug on the board there is two connectors which are for earth so link all the freen/yellow wires so the are all earth one way or other hope that helps
Feb 12, 2016 | Fisher and Paykel Washing Machines
Has a 5 pole socket for trailer wiring
Your terms are inconsistent.
Female 5 pole receptacle on the bike is what you need? You have a 4 pole male plug on the trailer?
You are looking for some sort of adaptor? Please show a picture of both ends, it would help.
May 13, 2014 | 1994 Honda GL 1500 SE Gold Wing
Wireing diagram for the cluch wires 1993 katana 750 from the handle bar?
The clutch switch circuit is a yellow wire with a green stripe. The handlebar switch has 2 male bullet type connectors that will pulg into female connectors of the same color. One will be on the harness from the r/h handle switch and I believe the other is on the main harness, r/h side of bike under fuel tank. It dosent matter which goes to which just mate male to female.
Jan 16, 2013 | 1993 Suzuki GSX 750 F (Katana)
Need wire schematics that goes too spark plug coils
I don't know if this will help or not. It shows the wire colors but not the actual connectors.
wo9vzmvvddnugaaaabjru5erkjggg==
Sep 09, 2012 | 1999 Pontiac Grand Am GT
A CH pressure sprayer PW175000AV Ser# 00842 was electrically taken apart without noting how wires were to be reattached. There are 4 male spade connectors on rocker switch which works fine. Power has...
Hello Woodnflies,
I understand that you need to rewire your pressure washer. I understand that you already have the switch wired and the motor wired as they are working. You need to power the pump that has a white (common) male and a black (hot) female. You what spade connections do you have open to connect too.
You should have a black and a white that have nothing attached to them this is where the pump wires are going to attache in the circuit.
Thank you for choosing FIxYa.com
Justin
May 05, 2011 | Campbell Hausfeld PW1750 Electric Pressure...
Westinghouse LF708C fault code SE. not spinning. what needs to be fixed?
SE refers to a sensor error, remedies include checking all connections plugs: § The connector (5pin, male, white) in the Wire Harness is not connected to the connector (5 pin, female) of Hall Sensor in the MOTOR. ?_? reconnect or repair the contact in the connector The electric contact between the connectors (5 pin, male in the Wire Harness and 5 pin female in the Hall Sensor) is bad or unstable. ?_ Reconnect or repair the contact in the connector ? The connector (6 pin, male, natural) in the Wire Harness is not connected to the connector (6 pin, female, natural) of PWB ASSY(Main) or the electric contact of connectors is bad/unstable. ?_ Reconnect or repair the contact in the connector ? The electric contact between the connectors ¡a6 pin, male in the Wire Harness and 6 pin female in the controller(Main)¡bis bad or unstable. ?_ Reconnect or repair the contact in the connector ? The Wire Harness between Hall Sensor in the MOTOR and PWB ASSY(Main) is cut(open circuited). ?_ Repair/replace the damaged WIRE HARNESS ? The Hall Sensor is out of order/defective. ?_ Replace the Motor ? The controller(Main) is out of order/defective. ?_ Replace the PWB ASSY(Main)
Jan 22, 2010 | Westinghouse Washing Machines
1995 Isuzu Rodeo 4X4 3.2 5 speed manual, reverse lights on in 1st
the wiring on the gear box is connected to switches wrong, there bullet head connectors red to red wiring and blue to blue from switch to loom is correct
both wires on one switch are red connect these to the 2 red wires one has colour trace on it also. the other switch blue wires to blue wire on loom with possibly another colour wire but they are together. you cant go wrong the connectors are male on one wire and female on the other on each switch(detent switch)
Nov 22, 2009 | Isuzu Rodeo Cars & Trucks
How do I disable the security system. I am having
Here is the full procedure of how to do this bypass the system, it is not easy..
Alright, let's begin the madness: 1. Take your DMM, set it to measure Ohms (use the 20k setting.) Measure the resistance across the pellet of the ignition key. Place one probe on the silver part of one side of the pellet, and the other probe on the other side. Write this value down. 2. Purchase a resistor or resistors that add up to the value measured in step 1. Radio Shack2.gif is a great place to go for the resistors, heat shrink tubing, and the "bullet-style" solderless connectors. 3. Take the 16 ga. wire and cut into 2 four-inch pieces. 4. Strip off approx 1/16" of insulation off each side of both wire pieces. 5. Put your resistors together in series (or if you're lucky and have a chip that has a resistance that matches a single resistor) and solder one wire to one end of the resistor(s) and the other wire to the other side. Example: You measure 11.72 on the 20k (k meaning kilo or 1,000) scale. The closest match is 11.801 which is a #15 "chip." Always remember that resistors have a tolerance of 2%, meaning the resistance value of the "pellet" can be either 2% higher or 2% lower than 11.801 k ohms (11.72 falls in tolerance range.) You will want to aim for 11,801 ohms. So when you go to Radio2.gif Shack you want to pick up a 10,000 ohm (10k,) a 1,000 ohm (1k,) and an 800 ohm resistors to wire together in series to achieve the 11.801k ohm value. Here's an example of how you'd connect the above mentioned resistors in "series" wire------10k ohm------I------1k ohm------I------800 ohm------wire 6. Measure the resistance across the 2 wires now that the resistors are soldered to them. Be absolutely sure the value matches that of the resistor pellet in the ignition key (within 2% up or down.) 7. Cut a length of heat-shrink tubing to cover up the resistors, allowing a small bit to hang over onto each of the 2 wires. Use a lighter or heat gun to shrink the tubing. 8. On one of the wires, crimp on a male bullet connector, and on the other wire crimp on a female bullet connector. 9. Now what you have should look like this: Notice in the above "resistor pack" I lucked out and only needed 1 resistor to match the pellet's resistance. You may not be so lucky... 10. Now move to the car. Remove the under-dash kick panel. 11. Look for an orange wire running down the steering column. This wire should have a "rubbery" feel to it, and it is the only orange wire running from the column. **WARNING** Do not tamper with any of the wires near the column wrapped in yellow harness tape or any yellow wire. These wires are for the airbag. Tampering with any of these wires could result in the airbag discharging. 12. Cut this wire (there are 2 small wires inside) and strip back the insulation on the wires on the opposite side of the steering column. 13. Install a male bullet connector to one of the 2 wires, and a female on the other. 14. Plug in2.gif your "resistor pack" that you made by mating the male and female bullet connectors. 15. Attempt to start the car. If your problem was with the VATS reader in the ignition lock cylinder, this will start the car. If this won't start the car, then the problem is in the VATS module. If the VATS module is bad, remove the resistor pack. Strip the insulation off the other side of the main wire cut (running from the column) and place a male connector on one wire and a female on the other. Plug the 2 halves back together to restore the function of the VATS reader. Alright, let's begin the madness: 1. Take your DMM, set it to measure Ohms (use the 20k setting.) Measure the resistance across the pellet of the ignition key. Place one probe on the silver part of one side of the pellet, and the other probe on the other side. Write this value down. 2. Purchase a resistor or resistors that add up to the value measured in step 1. Radio Shack is a great place to go for the resistors, heat shrink tubing, and the "bullet-style" solderless connectors. 3. Take the 16 ga. wire and cut into 2 four-inch pieces. 4. Strip off approx 1/16" of insulation off each side of both wire pieces. 5. Put your resistors together in series (or if you're lucky and have a chip that has a resistance that matches a single resistor) and solder one wire to one end of the resistor(s) and the other wire to the other side. Example: You measure 11.72 on the 20k (k meaning kilo or 1,000) scale. The closest match is 11.801 which is a #15 "chip." Always remember that resistors have a tolerance of 2%, meaning the resistance value of the "pellet" can be either 2% higher or 2% lower than 11.801 k ohms (11.72 falls in tolerance range.) You will want to aim for 11,801 ohms. So when you go to Radio Shack you want to pick up a 10,000 ohm (10k,) a 1,000 ohm (1k,) and an 800 ohm resistors to wire together in series to achieve the 11.801k ohm value. Here's an example of how you'd connect the above mentioned resistors in "series" wire------10k ohm------I------1k ohm------I------800 ohm------wire 6. Measure the resistance across the 2 wires now that the resistors are soldered to them. Be absolutely sure the value matches that of the resistor pellet in the ignition key (within 2% up or down.) 7. Cut a length of heat-shrink tubing to cover up the resistors, allowing a small bit to hang over onto each of the 2 wires. Use a lighter or heat gun to shrink the tubing. 8. On one of the wires, crimp on a male bullet connector, and on the other wire crimp on a female bullet connector. 9. Now what you have should look like this: Notice in the above "resistor pack" I lucked out and only needed 1 resistor to match the pellet's resistance. You may not be so lucky... 10. Now move to the car. Remove the under-dash kick panel. 11. Look for an orange wire running down the steering column. This wire should have a "rubbery" feel to it, and it is the only orange wire running from the column. **WARNING** Do not tamper with any of the wires near the column wrapped in yellow harness tape or any yellow wire. These wires are for the airbag. Tampering with any of these wires could result in the airbag discharging. 12. Cut this wire (there are 2 small wires inside) and strip back the insulation on the wires on the opposite side of the steering column. 13. Install a male bullet connector to one of the 2 wires, and a female on the other. 14. Plug in your "resistor pack" that you made by mating the male and female bullet connectors. 15. Attempt to start the car. If your problem was with the VATS reader in the ignition lock cylinder, this will start the car. If this won't start the car, then the problem is in the VATS module. If the VATS module is bad, remove the resistor pack. Strip the insulation off the other side of the main wire cut (running from the column) and place a male connector on one wire and a female on the other. Plug the 2 halves back together to restore the function of the VATS reader
Oct 06, 2009 | 1994 Buick Park Avenue
Digital clock
Here is a wiring diagram of the radio by wire color:
Radio Constant 12V+ Wire: Green/Yellow
Radio Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Green
Radio Illumination Wire: Light Blue/Red
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Blue
Radio Amp Trigger Wire: Blue (Same as Antenna Trigger)
Front Speakers Size and Location: 5′ x 7′ Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers SIze and Location: 5′ x 7′ Rear Deck
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Aug 14, 2008 | 1988 Ford Mustang
Hoisting Logo
507 people viewed this question
Top Hoisting Experts
AZBen
AZBen
Andrew Taylor
Andrew Taylor
Pierre Laplante
Are you a Hoisting Expert? Answer questions, earn points and help others
