SOURCE: Can't print onto thick card
In your print driver, you need to go to the Printer Features -> Media 1 window and specify "Thick 2" and then go back to the main print window and specify Paper Feed "Tray 2" Then go to the copier,, place the stock into tray 2 and match the paper setup for that tray on the copier to "Thick 2" for tray 2.
Basically, both the Mac and the copier need to match paper types and feed tray.
SOURCE: Printing on thick paper (thick 3)
You can print thick 3 only from bypass tray.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
SOURCE: My office has the bizhub
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
