Can't find the ILO tv on the list when programming my Direct TV Remote
I have two tvs 1 is an Ilo and the other is a Sylvania. the code for sylvania works for both tvs on the Direct Tv Remote Hope this all helps and here is the code. 10171, there are also two other codes for this tv and they are 10054, and 10030. Have a good day and happy watching.
Darklove_420
SEARCHING FOR YOUR CODE IN AV1 OR AV2
MODE
If you were unable to find the code for your brand of TV or
component, then you can try a code search. This process may
take up to 30 minutes.
1. Turn on the TV or component.
2. Move the slide switch to the AV1, AV2 or TV position.
3. Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch position
flashes twice and then release both keys.
4. Enter in 9-9-1 followed by one of the following 4-digits:
COMPONENT TYPE COMPONENT ID #
Satellite 0
TV 1
VCR/DVD/PVR 2
STEREO 3
6. Point the remote at the TV or component and press
CHAN . Repeatedly press the CHAN until the TV or
component turns off.
Note: Every time CHAN is pressed the remote advances to the
next code and power is transmitted to the component
7. When the TV or component turns off, stop pressing the
CHAN key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component
responds, then you've cycled through all codes and unfortunately
the code you need is not available. You must use the remote that
came with your TV or component.
Here is the link to your manual:
http://www.directtv-advisor.com/support-files/direct-tv-remote-manual.pdf
I have a comcast cable hd remote. I can't find the code # for my ILO 26" HD tv. I tried the search code but could not find one. Is there a remote that will work both the cable box and TV?
Thank you
Anyone found a fix for this?
