Makes noises when drum tumbles.
GOD IS GOOD !!!!
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
SOURCE: help with a noisy Fisher & Paykel dryer
I have the same problem. Replacing the front glides (two glides cost under $20 plus labor and service call). The second time it seems to be more than the front glides. Service tech says that it is the blower moving back and forth on the motor shaft. (Because of a worn indentation on the shaft..). Therefore, he says that I must replace the motor and the blower--parts cost approx. $290, plus labor and service call. Ouch! Also says that the plastic front support piece is worn. More money! So, I am looking at a new dryer instead of trying to patch up the one I have (it's out of warranty.)
SOURCE: Fisher & Paykel Electric dryer wont tumble
I had the same problem,fixed it today with a replacement capacitor,cost $10 2nd hand (only cos I couldnt find a new one today and wanted it fixed now!)Unplug appliance, took off the back panel,underneath the motor on bottom left is the capacitor,remove the 2 wires, pull the capacitor out its bracket,replace,refit the 2 wires,replace back panel and Badabing Badabang!! My machine is working to full capacity again.
Pays to check out these forums doesnt it!!!
SOURCE: squeaking dryer drum when operating
sounds like you need to adjust the motor that turns the drum to tighten the drive belt..... you do this from the back or bottom...
SOURCE: Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
SOURCE: My dryer is a top loading Fisher and Paykel and it
It could be bearing or guide in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
f the noise is coming from the right side of the drum and the unit is over 5 years old the bearing is most likely worn and needs to be replaced. you can pick up on the right side of the tub to determine if there is any play, if so replace the bearing kit.
