Detailed Description
This article covers whether a QuickCam work on a Macintosh computer.
Answer
This article applies to the following operating systems:
Mac OS 10.1.5 - 10.2.6
NOTE: Later versions of OSX are not supported by QuickCam.
To use a Logitech camera on your Mac OS X computer, please consider
the following models: QuickCam Orbit, QuickCam Pro 4000, QuickCam Zoom
P/N 961325-0403, the Pocket Digital and the Pocket Digital 130. The
Logitech Pocket Digital 130 is supported natively, so all you have to
do is plug it in. You can then use it in iPhoto™, a program that comes
with Mac OS® X.
To use the Pocket Digital, you must install the Pocket Digital driver, available
HERE. You can then use it in iPhoto™, a program that comes with Mac OS® X.
If you would like to use any of the other cameras mentioned, you must install QuickCam 8.0.1, included with the camera.
NOTE: QuickCam 8.0.1 should only be installed in Mac OS 10.1.5 - 10.2.6.
Mac OS 9 (OS 9.0.4 - 9.2.2)
To use a Logitech camera on your Mac OS 9 computer, please consider the
following models: QuickCam Pro 3000®, QuickCam® Pro 4000 and the
QuickCam® for Notebooks Pro. In order for these cameras to work, you
must install QuickCam 5.0.1, which is included with the camera. It is
also available
HERE.
For additional information regarding UVC camera support under Mac OS 10.4.9 please see article
6471
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=51
Hi Jeff Mayweather, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What OS system will you be installing?
I want to reinstall OS X 10.6 on my Mac Pro.
Did you make a recovery disc of the 10.6 when you got the system? If not you need to go to a Genius Bar and they can roll it back for you.
Yes I Have a copy of OS X 10.6!
You need to have your hard drive backed up separate hard drive or with a provider like Crashplan. This is paramount unless you don't have anything on the current hard drive that you need to keep.
Once you have everything backed up put the disc in and follow the instructions. It will warn you that you are stepping back. The reason you need everything backed up is because it may not give you the option to just install a new OS but may reset your hard drive.
Why would you want to uninstall the OS? What are you going to replace it with??
OS 10.6
