SOURCE: My Skyworth LCD TV 32
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. If you're
under warranty, this will cost you nothing. If you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
SOURCE: pc connected to th42phd7 but no picture, input button doesn't
are you on the right input. To use this set as a monitor you do have to change some settings in the options part of you tv. Also you need to make sure the set is on the right resolution for the PC. check you video options on the PC, and make sure they are the same on the TV set. Also you will not get sound from this type of cable..good luck
