I have a uniden Washington no sound out of the speaker but it is receiving you can tell by the s meter moving. It transmits fine and my voice can be heard on other radios GOOD AND LOUAD when I key it up.HELP!
Do you have the volume turned up? Squelch turned all the way left and RF gain all the way right. If you still don't hear anything check to see if this model has a dynamic squelch .If it does turn it off.
Testimonial: "checked all of that before posting my problem"
SOURCE: Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
SOURCE: CB RADIO UNIDEN WASHINGTON PC-385 PCB
VR3 adjusts the transmit frequency. It's located near the center of the PC board close to the front panel. As this is a hit-or-miss operation, it would be wise to use a frequency counter when attempting it.
SOURCE: Uniden Grant XL No Transmit
on the back of the radio you will see a small circuit board with a transistor on it this is your am regulator.check to see if that has gone bad
SOURCE: CB Radio will receive but not transmit
Sound Like The Modulation Amp May Be Dead..
Or a Componet in The Mod. Section....You Can Pick up The Repair Manual..@ www.samswebsite.com For about $20.00...Good Luck
SOURCE: Radio stuck in transmit meter needle is slammed all the way to the right as soon as you turn unit on
Have you recently changed mics ? if so it is wired wrong, if not I would check for a shorted wire in the mic connector or the mic itself.
