I need to separate the treadmill from vertical bars
SOURCE: My Nordic Track Exp 1000 X runs in reverse.
Your treadmill runs on a permanent magnet DC motor. If it is running backwards someone has swapped the pos and neg leads where it connects to the motor control board MC-60. OR
the brushes were removed from the motor, and installed into the WRONG locations. there is a plus sign and a neg sign on the end cap of the motor, make sure the RED wire is going to the pos sign,.and so forth.
to get to the motor you'll need to remove the 4 phillips head screws FROM the bottom of the motor enclosure: lay the unit on it's side to get to them. 2 in the front,.and 1 on each side. If it doesn't come off easy,.you've missed a screw.
Lay the unit back down, and start digging in.
Lastly, you can verify the MC-60 is outputting the wrong polarity voltage with a voltmeter. Disconnec the motor and connect your voltmeter on a 20 volt DC range ( at least). plug your unit in, and turn it on at 3 mph. you should see positive voltage applied to the read lead.
It's very unlikely that the control board would swap the polarity, so, my bet is,...the wires are switched.
good luck.
SOURCE: how do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
SOURCE: I need a owners' manual for a Nordic track exp
You can download a free one at www.iconservice.com.
SOURCE: my nordic track treadmill exp 1000 keeps stoping how can i fix this
Dear Sir:
LUBE the treadmill in according with the instruction manual, and take the step.
2) Adjust the speed sensor, see the diagram attached, clean, and tigh the connector very well
3) See the input voltages for the main motor, coming from the m motor board
4) Test the output from the main motor board for input to the main motor.
5) See my personal TIPS for HELP
sincerely. God bless you
