Homelite Mighty Lite Lawn Trimmer  Logo
Posted on Jul 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Starts then dies stihl fs45/weedeater
It ran good untill it ran out of fuel now it will start but dies when i pull throttle and it wont idle
Anonymous
Level 3:
President:
  • Master 1,776 Answers
  • Posted on Jul 05, 2009
Anonymous
Master
Level 3:
President:
Answers
1776
Questions
0
Helped
646202
Points
6310
I sounds like it sucked up some debris in the bottom of the fuel tank and obstructed fuel flow somewhere. Start by blowing out the in-tank fuel filter (You will have to fish it out with something), then load the line with carb cleaner (wear safety glasses) put fuel filter back in line and crank it a few times to pull the carb cleaner into the carb. This may dislodge the obstruction. If this doesn't work, you will have to remove and cleant he carburator. Hope this helps.
2answers
I have a Stihl MS 181C. It starts, no problem, but the chain runs on tickover and when I squeeze the throttle it cuts out. Can you please advise.
fuel filter --air filter --bad fuel--carb /cleaning /rebuild /replace-fuel line - binding clutch--tension to tight on chain
2helpful
Parts and repair manual for a Stihl FS45 weedeater
most times it is easier to do just that
Homelite trimlite weedeater will start and idle in full choke position only. Cannot use any throttle or it dies. Cannot switch out of full choke or it dies. Cannot use any throttle to start it as well, if...
Fuel starvation either too the carb or in the carb itself, start with a simple cheap fix, replace the fuel filter in the tank on the end of the fuel hose.
Aug 16, 2013 • Garden
Can't start new stihl weedeater fs 45
The Stihl FS45 has a particular way of getting started as do all the stihl products. We sell Stihl equipment in our store and service and repair them also. The normal starting procedure is to:
Be sure the switch is turned to the ON position which is the negitive sign (-). The (O) is the off position.
Press the primer bulb 3 times.
Move the choke lever to on.
Pull the starter cord three times only. If the engine fires, turn the choke to the off position and pull till it starts.
If the engine did not try to start during the first three pulls with the choke on, you must turn the choke off and pull till it starts.
Remember:Pulling more than three times with the choke switch on will flood the carburator on every stihl product thats on the market.
However, if the units still refuses to start, being its new and still under warrenty, return it to the repair shop that services Stihl products and they will repair it according to warrenty. All parts and labor should be honored at no cost to you. Please provide your receipt and serial number located on a silver tag located on the unit or the mechanic will get it off the unit when he works on it. Either way, it will most likely have to have a new carburator put on it. I hope this helps. Please comment back if this was helpful. Thanks; George
4answers
Stihl FS45 will not run at full throttle
replace fuel filter in the tank and will be fine it is gummed up .stock part at any sthil dealer
Aug 22, 2009 • Garden
2helpful
Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Jul 25, 2009 • Garden
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
