Canon PowerShot G11 Digital Camera Logo
A
Anonymous Posted on Sep 29, 2014
Line through photos
When I download photos there is a line running from top to bottom through all photos.
Naor Gamliel
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Jan 08, 2015
Naor Gamliel
Contributor
Level 1:
New Friend:
Answers
15
Questions
Helped
1078
Points
49
Does it also show up when you display the images on the camera?
if so, its probably a camera issue, if not re-install the camera driver and program - it might solve this problem
good luck
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
2answers
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
2helpful
Ryobi cultivator #RY60511A : Need diagram or text to show the fuel lines from the tank to the primer and the carburetor.
here is a manual,Tim:
http://lawnandgarden.manualsonline.com/mdownloads/38dcb043-331f-461b-a08c-072d67fc76c0.pdf
here is a diagram:
http://photos.hobbytalk.com/showphoto.php/photo/34693
in a nutshell:
1 connect top carburetor line to short nipple on primer bulb.
2 bottom carburetor line to fuel line with filter (inside tank).
3 connect remaining fuel line that comes out of fuel tank to the large nipple on primer bulb.
Hopes this helped Tim
May 29, 2011 • Garden
1helpful
I had a wireless router installed and can no longer fax using CX9400FAX series. Receive communication error ''no dial tone''. There is a phone line from the phone to printer and from printer to wall jack....
I too was having the same problem. We too have a wireless router hooked up. However, that had nothing to do with the problem. Our problem was that the top phone line port on the fax machine should run to the phone jax in the wall. The bottom phone line port on the machine should run to the phone. We had them switched around.
I hope this helps.
2helpful
Bottom of line missing
First try and go to page setup under file and set your bottom and top margins to .25. is every bottom half line faded? If so then yes you might need a new ink cartridge.
Line on photo
Have you tried to pixel map the camera, It is a menu setting option probably in the wrench 2 tab of the camera menu. This will try to fix any information with the CCD chip inside the camera that controls image processing. If you run this function and it still shows the red line then it may be that you need to send the camera in for repair to have that CCD chip replaced.
A black line on the top and bottom
In your Recording Menu, check that the Disp. Overlay is turned Off. The lines are showing the portion of your image that will be cropped if you print a 4 x 6 photo (3:2 Guide).
Printing out thepictures
Try printing the picture from another program. Or with less resolution.
If that doesn't work, try reinstalling the printer and downloading the latest drivers from the HP website.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
