Hi i have a rotel ra-610 amplifier and am having intermitent static on the right hand channel only how do igo about fixing it?
  • Audio Player... Master
  • 5,699 Answers
I would prod and poke the channel with an insulated screwdriver this will cause buzz sounds. This should find the cause of the problem. Remember that the left hand channel is identical so you can compare the right with the left. For example if you get a weird buzz on the right when you touch it, but not on the left at the same point you might have found the faulty part.
Don't go near the power supply section as it's nothing to do with that the fault.
Posted on Oct 07, 2014
SOURCE:
  • 319 Answers
SOURCE: Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Posted on Apr 17, 2008
robotek
  • 1512 Answers
SOURCE: Are you able to provide a circuit diagram or even
I am sure I have fixed this model in the past. A lot of Rotel gear of this vintage, although sounding quite good, had been farmed out  to Taiwan for manufacture. This was back in the day before electronics came from China. But the quality of the build was often low grade, and hand assembled with custom made IC's and transistor arrays that are no longer available due to local manufacture(taiwan). Some gear was Japanese and better build quality.   Look for a 5 legged transistor (small black bodied device) device, or blackening of the legs of any  transistors(black death i call it).Is it possible to post an in focus  picture pof the internals to jog my memory on this amp.
Posted on Mar 04, 2009
  • 133 Answers
SOURCE: Have Rotel RB-1080 stereo power
Try to plug a set of headphones into your amp.
If only one is working this means that either you're not getting both signals into the unit (check the signal input connectors, resolder any bad contacts), the signal doesn't get to the preamp or from the preamp into the power amp or the signal does not come from the power amp (check solder connections on preamp and power amp components, also check internal connectors - unplug, clean, reconnect).
If both headphones work well instead, then you're getting both signals into the unit and the preamplifier and the final amplifier are OK, since many amps derive headphone signal from the power amplifier via some power resistors - check for any power resistors around the headphone plug or in the section that has wires going to the headphones plug to see if this is the case - if it is, this means that the signal does get amplified, but it is not getting from the power amp to the speaker - in this case, check the following:
--- speaker connector solder contacts on the circuit board could have some damage - resolder if necessary
--- A / B speakers selector switch (if there is one, it could be a physical switch or a soft touch button driven relay so check for both) - there might be a bad solder contact on the switch pins or the switch / relay contacts may be dirty - resolder and/or clean the contacts (if they can be easily accessed).
--- final amplifier section: bad solder contacts on any power transistors, voltage regulators, power resistors, diodes, coils or other components, including internal connectors (anyway, if both headphones work well, these are all unlikely because the power amp is sending both signals out OK, however, you may want to give it a check, just in case...)
--- delayed speaker turn on relay or other relays - check for dirty relay contacts, clean with some fine sandpaper (you need to remove the relay cover which can be a bit tricky / difficult to access, mostly it's a snap-on cover, could also be resin filled and therefore impossible to open).
It could as well be a bad power amp (do the headphones test), the above suggestions are just a quick look at some common audio amp problems and possible solutions.
Also, if your unit has got many hours of use, it would be fair to check the input signal connectors - the solder contacts do get damaged when you plug / unplug the RCAs many times.
Hope all of this is not getting too lenghty and confusing... just post me some feedback if you have questions.
regards
3rq8 (Triarcuate)
Posted on Sep 10, 2009
  • 4234 Answers
SOURCE: Hi, I have a second hand NAD 3240PE amplifier, the
Crackling is usually a dirty control. Try using an electronics cleaner (with lubricant) and spray out all of the controls and switches. With the unit off, work the controls and switches back and forth to "spread" the lubricant. I would spray, work and spray again.
Update this with the results and also see if the crackling is related to the overall volume level. If tied to the volume level, there could be a transistor inside that is breaking down and causing distortion.
Dan
Posted on Dec 28, 2009
  • 211 Answers
SOURCE: the two 5 amp fuse inside the amplifier keeps blowing
That must be the inrush current.
Maybe you are using the wrong fuses.
Please check if those are fast or slow types.
You need slow types.
Good luck,
Gerard
Posted on Jan 17, 2010
HALLO I HAVE A ROTEL RA 9858X AND AGTER PLAYING FOR A FEW MINUTES I LOSE THE RIGHT SPEAKER CHANEL
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
Jun 14, 2014 | Rotel Audio Players & Recorders
Tip
REPAIR ASSISTANCE
ROTEL RA 980BX
Fault: No output from left channel. The right channel is working fine.
Added some photos and circuit for reference
While testing the amp noticed that the left channel is giving switch on off thump while powering ON and OFF the amplifier. It happens when there is DC voltage flow through the speakers. It shouldn't be there. And the thump is there only on the left channel. While testing the amplifier section found that all the transistors where idling at mentioned voltage. All Base pins where around +/- 0.5volt. and the output is almost 0.012mvdc.
FOR MORE DETAILS CHECK THE LINKS
http://electro-medical.blogspot.in/search/label/ELECTRO%20MED%20SERVICES
on May 17, 2015 | Miscellaneous
I cannot get equal volume on both channels. It snaps crackles,
If it's an old type control then you can spray it with Servisol switch cleaner. You might have to take the top cover off to get better access.
May 27, 2013 | Rotel Ra-2030 Integrated Amplifier Review,...
Rotel RA 12
I think RA 12 is not existing type, but RA 12xx types exist.
Please try this link, and I hope you will find the relevant documentation.
gylacz
Mar 18, 2013 | Audio Players & Recorders
Alesis RS300 Reference Amplifier Channel malfunction...
You say "it seems like". Do you mean to say it is intermitent, or did it start cutting out and then finally fail? If that is the case I would look first to replacing the relay in contention in this thread.
http://www.fixya.com/support/t224708-amp_cuts_out_after_while
It's a cheap fix and will eliminate one potential cause. The Radio Shack part is widely available.
http://www.radioshack.com/product/index.jsp?productId=2062483
My RS-300 had started dropping the left channel, but occasionally both. It is possible that the relay has failed on one side and thus you have a dead channel...I did the fix and am now quite happy with the amp
Steve
Dec 26, 2009 | Alesis RA-150 Amplifier
My Rotel RA-931 integrated has an intermittent left channel. It occasionally cuts out or loses most of its volume. The key thing is this: if I crank the volume it'll suddenly come back and be okay for a...
This could be a bad solder joint, or dirt in the volume control. Try spraying the volume control with Servisol Video 40, available from electronic shops such as Maplin, or Radio Shack.
Dec 22, 2009 | NAD C272 Amplifier
Manual circuit diagram
I don't believe that Rotel service manuals are available outside of authorized service centers. Can you provide us with the problem that you have? Perhaps we can guide you through the repair.
Thanks,
Dan
Sep 20, 2009 | Rotel Audio Players & Recorders
I have a rotel RA - 820B x 3, that has stopped working.
Hi Nell. It is serious. Unless you are technically inclined, it needs to be checked out by qualified person. It will be fairly expensive to repair. Get an estimate.
Thanks
Paul
Jul 12, 2009 | Audio Players & Recorders
Problem with Rotel RA 870
Since it is a Rotel, it is a good unit and worth fixing. At this point, you need to take it to a good repair shop and let a qualified tech look at it. There are no user serviceable parts inside and if you go poking around in there, you WILL make the problem worse. Rotels' are nice units and represent a good value in stereo gear. Take it to a reputable repair shop that repairs Rotel under warranty. If thats not available to you, then a good repair shop should be able to get you going. Good luck...Rob
May 09, 2008 | Audio Players & Recorders
151 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
