SOURCE: I started my microwave and
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
It's safe to run in the very short term, but if you run it too long without fixing the blemish, it may arc and char more.
SOURCE: Need to replace Panasonic NE8070 model, 15in dia,microwave plate
hi my name is mark, i found panasonics part website follow link http://www.pstc.panasonic.com/Epartr/PartsListChoice.asp?validate=1 if this helps please rate how i did. thanks for you question.
SOURCE: Panasonic Microwave Model NN-H765BF will rotate
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If
yours is not set to be off via the control panel, and it won't rotate
or it sounds like it's grinding, etc., you may have a bad motor or
plastic coupler.
To
replace either, you need to unplug power, then remove the bottom cover
of the oven.
You can order parts Encompass here or call them toll-free at 866-779-5835.
We're
We're
SOURCE: our oven's glass plate is broken i want new glass
After some research I discovered that Electrolux is the parent company of the common brand Frigidaire.
From the looks of it, the best place to order the part you need is from Sears Parts Direct. While there were several other parts companies which popped up, Sears seems the most legit, and the prices they advertise were actually cheaper than the other sites.
The part you need has the manufacturer product code: 5304461145
If you look at the schematic (http://c.searspartsdirect.com/lis_png/PLDM/R0908182-00001.png) you will see the tray labeled as part #45. This code matches the last two digits of the product code, so I'm fairly confident that this is the correct part.
The part is currently priced at $135.43 without tax or shipping.
You can purchase the part online at this link:http://www.searspartsdirect.com/partsdirect/part-number/Electrolux-Parts/Microwave-Parts/5304461145/0022/628/Model-E30MO65GSSB/1412/0123100?keySuffixId=&productTypeId=&searchModelNumber=E30MO65GSSB&blt=06&subCompDesc=OVEN/CABINET
