AUDIBLE TONES
Selects the volume.
KEYPAD VOLUME
Selects the beep volume when pressing the buttons on the Operation Panel.
ALARM VOLUME
Selects the alarm volume.
PWR SAVE SETTING
Specifies the time to switch the machine to the Power Saver mode.
COUNTRY SELECT
Selects the country where you are using your machine. This setting is not available in some
countries and regions.
LANGUAGE SETTING
Selects the language for LCD messages.
RESTORE DEFAULT
You can change the settings back to the settings on your purchase (some data may not be reset
depending on your usage condition). Was on page 98 of this manual in link.
Canon MP530 User Manual Others Restore Default
Select a different language after initial setup
1 From the control panel, press Settings.
2 Press left or right arrow repeatedly until Device Setup appears.
3 Press tick.
4 Press left or right arrow repeatedly until Language appears.
5 Press tick.
6 Press left or right arrow repeatedly until the language you want appears on the display.
7 Press tick.
8 Press left or right arrow until Yes appears.
9 Press to save.
Hope that helps, if it does please rate my help. Thanks
Please check the bellow links related to your issue:-
http://www.ehow.com/how_6937245_reset-toshiba-lcd-tv.html
http://www.ehow.com/way_5365855_toshiba-lcd-tv-troubleshooting.html
Otherwise as a general rule if you go into the set-up menu you can usually find an option to change the language in there.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
